Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (SandraD, baldeagle, farmallb, Peggy M), 51 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#1190990 11/15/2016 4:12 PM
Hello,new guy here. I have a 49 gm 228 that I'm starting to disassemble. I'm planning on drilling and tapping crank snout for a hold down bolt which it never had originally.Ive read the threads about the actual drill and tap and im good with that. My question is,when I go to reassemble do i need to cut off the hand crank ears or whatever there called on the front of damper and grind so the bolt and washer fit flush to front of balancer? Thanks in advance. I've learned a ton already by searching this site.
1949 gmc 1-ton
It's very simple to counterbore the hand crank lugs to create a step for a washer to bear against. I've offered to machine balancers for people who have bought my drill and tap kit, but so far nobody has taken me up on it.
Thanks for the info Jerry. Must say I never thought of milling the inside
1949 gmc 1-ton
