0 members (), 148 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#1190462 11/10/2016 8:24 PM
I
I Offline
I'm trying to get the spider gear pin retaining screw out and it's stuck, I've used all my strength on a big screw driver.. any ideas?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
I
I Offline
Nevermind pair of vice grips on a screw driver got it!
(I'm 20)
"Lucy"
Your a lucky man. I've seen those screw/bolts pop into and be a nightmare. Count your blessings!
If the wood block to stop the gears from turning and large screw driver with a wrench on the shaft does not work .............
The old hand hammer impact with a large straight bit will do the trick every time . Like this:
