1 members (Bill Hanlon),
217
0
Mod | | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I'm trying to get the spider gear pin retaining screw out and it's stuck, I've used all my strength on a big screw driver.. any ideas? | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Nevermind pair of vice grips on a screw driver got it! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Your a lucky man. I've seen those screw/bolts pop into and be a nightmare. Count your blessings! | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | If the wood block to stop the gears from turning and large screw driver with a wrench on the shaft does not work .............
The old hand hammer impact with a large straight bit will do the trick every time . Like this:
