3 members (cmayna, tclederman, Otto Skorzeny), 139 guests, and 1 robot.
Topics128,134
Posts1,056,402
Members48,441
#1190422 11/10/2016 4:34 PM
I
I Offline
I have an axle leaking bad and I gotta fix it. (Yes I made sure the breather was clear). I've got the differential caver off and the drum off.
I can see the c clip but there's like a box in the center of the gears keeping me from getting to it. So can someone tell me how to get that c clip off?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
There is a pin that runs through the spider gears to hold them in place. That pin has to be removed to move the axle in far enough to remove and install the clip.
There is one small bolt at one end of the pin to remove and the pin will come out. Once the pin is out the axle can be push further into the differential to remove and then install the pin.
If you are careful the gears will stay in place.
Really not a hard job to do once you get the pin out, and once the bolt is out it may fall out or take a light pressure to pull it out.
That "box" is the axle spacer. Pay attention to the orientation of the spacer which should not have more than 0.014" gap between the side of the spacer and end of axle. That spacer can be turned one quarter turn to either increase or decrease that gap, as the spacer is machined to different dimensions.
Roy Rodgers has it right but it might help to look at a service manual description of this process. Google "Keith Hardy Chevy Manuals" and look under the rear axle section.
kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I
I Offline
I found the bolt but it's a slot and it's stuck, any ideas to get it loose?
(I'm 20)
"Lucy"
Grind a screwdriver bit so it's a very snug fit in the slot, and use a pair of vise grips on the screwdriver shank to turn the bolt out. A little heat with an acetylene torch on the carrier housing in the area of the bolt won't hurt anything and might help it break free.
Jerry, he posted in another forum, he got it loose. BTW good tip about grinding an old screwdriver to fit the slot better. That can go for many stubborn bolts.
I
I Offline
I basically did exactly what hotrod Lincoln said including the torch. Don't really know if the torch was needed but didn't hurt.
(I'm 20)
"Lucy"
