1 members (1 invisible),
368
Mod | | | Forums66 Topics128,162 Posts1,057,043 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 23 New Guy | | New Guy Joined: Sep 2004 Posts: 23 | I'm not restoring my '46 1/2 ton, just fixing it up. But I'd like to fix it original and I can't find out the color for the valve cover. Was it blue or black or what? And what kind of cap did it have on the valve cover for the oil? Mine has one that probably used to have steel wool in it, but now the steel wool is gone and it spits oil back out and gets the valve cover dirty. Any suggestions on how to fix that? What color were the wheels? I'd guess black with some color stripes. Sure do need help. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Feel free to browse my photos.....you'll see many original and restored versions....Have fun!
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jan 2005 Posts: 52 Member | | Member Joined: Jan 2005 Posts: 52 | The wheels on the 41-46's were either black or the same color as the body and had pin stripping on them. The 216 motor was gray, top to bottom. The valve cover cap is just a non breathable twist on cap with no vent in it. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | There is an engine enamel from Plasti-coat called New Ford Gray #216 in the tall rattle can that matches pretty close. If you just want to spruce up your engine a little, that should work.
I finally get to use my quart of actual spray on engine paint now that my 216 is out of the truck. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | You can find the right engine color for your 46 at the Filling Station www.fillingstation.com Item # FS119 pints $26.50, quarts $45.00 high temp enamel. The correct color
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Sep 2004 Posts: 23 New Guy | | New Guy Joined: Sep 2004 Posts: 23 | Thanks for all the good info. Tim, I know now why I'm just fixin it up instead of restoring it. Man, I drive it to work every day!
One more question. What color should the pin stripes be on black wheels, white? creme? | | |
