1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Working on my 58 Viking 60 with 2-speed rear end. Anyone know for certain what lube goes in the little shift box on the back of the speedo? Mine is binding up and spun off the speedo cable. It looks like dried out old grease in there but if I put a bunch of grease in it, it is a bit too stiff to shift. I am wondering if it I should use the same lube as the steering gea. I looked in my manual but did not find anything listed there. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | AC Delco made a grease for that. Came in tooth paste type tube. I'll look for a tube to get the part no. Maybe it still can be bought. Jeffrey | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I don't know if that shift box at the back of the speedometer is the same as mine in my '50 COE but mine had dried up Lubriplate in it. I disassembled it and put new Lubriplate 130 in it. It is the same white lubricant used for screw type garage door openers which comes in a tooth paste type tube which you can get at a hardware store. For you M1 Garand collectors it is the same tan lubricant used in WWII that came in the little plastic tubs (not the later Korean War stuff that lookes like ordinary grease).
Kent | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | is that similar to the white lithium grease that comes in a tube? | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | AC Type ST-800
AC No. 25033356
I forgot about this till I just saw this thread and just went in the garage to get this information. Jeffrey | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | |
