1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1189962 11/07/2016 5:49 AM
Big Bolt Forum Moderator
Working on my 58 Viking 60 with 2-speed rear end. Anyone know for certain what lube goes in the little shift box on the back of the speedo? Mine is binding up and spun off the speedo cable. It looks like dried out old grease in there but if I put a bunch of grease in it, it is a bit too stiff to shift. I am wondering if it I should use the same lube as the steering gea. I looked in my manual but did not find anything listed there.
Mike
AC Delco made a grease for that. Came in tooth paste type tube. I'll look for a tube to get the part no. Maybe it still can be bought. Jeffrey
I don't know if that shift box at the back of the speedometer is the same as mine in my '50 COE but mine had dried up Lubriplate in it. I disassembled it and put new Lubriplate 130 in it. It is the same white lubricant used for screw type garage door openers which comes in a tooth paste type tube which you can get at a hardware store. For you M1 Garand collectors it is the same tan lubricant used in WWII that came in the little plastic tubs (not the later Korean War stuff that lookes like ordinary grease).
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
is that similar to the white lithium grease that comes in a tube?
Mike
Yes,same stuff,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
AC Type ST-800
AC No. 25033356
I forgot about this till I just saw this thread and just went in the garage to get this information. Jeffrey
thanks guys!
Mike
