8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | What are the pros and cons of using all high pressure flex hose to and from the trans and cooler. I am using 350/th400 and the cooler is in the radiator. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Pro for rubber, easy to run
Pro for steel lines (cons for rubber hose), look factory/appropriate, cool better than rubber, longer lasting, easier to support with clips and prevent rubbing, probably higher pressure rated though not likely an issue. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Pro for rubber, easy to run
Pro for steel lines (cons for rubber hose), look factory/appropriate, cool better than rubber, longer lasting, easier to support with clips and prevent rubbing, probably higher pressure rated though not likely an issue. Good post. "cool better than rubber, longer lasting, easier to support with clips and prevent rubbing, probably higher pressure rated" And probably cost less. Jeffrey | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Thanks guys, that is what I was looking for. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | If you spring a leak in a rubber line (something you won't have happen with steel lines) you will trash your transmission before you know that you have a leak. It comes out fast.
| | | | | Joined: Feb 2004 Posts: 29,784 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,784 | I'd use stainless tubing mounted solid to the frame and the radiator, with short braided wire armored flex hoses to the trans to absorb any motor mount movement. Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Homer,
Complicated hard lines are not easy to make and if you can do it it showcases your craftsmanship and enhances the appearance of your project.
The stainless tubing that Jerry recommends probably cannot be double flared for common flare connections so AN fittings may be required. Stainless tubing does look very nice, though.
When I restored my '36 Chevy pickup over 40 years ago I used stainless tubing for gas lines and for the vacuum advance line from the carburetor to the distributor and it still looks as good as the day I installed it.
Ray W
Ray
| | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | I'm using braided flex 6an from th400 to cooler. There are specific fittings that needs to be replaced on the trans to accommodate the braided flex. I haven't decided how to keep the hose separate yet. I'm also using 8an braided flex from fuel tank to pump. The cost really isn't in the hose, as braided flex is relatively inexpensive. You'll bear significant cost in fittings. By flex, I'm assuming it is braided stainless steel over rubber hose that encases a fluid resistant teflon inner hose.
Admin for Turbobuick.com 87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
| | | | | Joined: Nov 2016 Posts: 5 New Guy | | New Guy Joined: Nov 2016 Posts: 5 | A good trick is to grab a couple drop ceiling hanger wires from the hardware store. they are long, and hold their shape. you can use them to make a template of your steel line in place, then pull it and bend your lines on the bench. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and Lowes carries them to and they are pretty long. | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | I suppose if you have the truck disassembled it would be feasible to route steel trans cooler lines, but working underneath the tight confines of an assembled truck often make this impractical. Most trans cooler kits come with rubber line, so the manufacturers must believe it to be adequate. Plus, calculate how old you are, how long you have left to live: modern high-pressure rubber line will probably outlast you.
When building a vehicle from the ground up, I typically use hard line up to the cooler, then rubber line to connect the two. I've never had a rubber line fail.
