1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 1,037 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,037 | I have a 53 3100. back in early the 80's I had a wheel bearing go out. At that time parts were hard to find and expencive. The 53 wheel bearing was many times more money than one a few years later. I had a newer front axle narrowed and bought bearings.The problem is that I have no idea what year it was. Now I am finally restoring it. I want to put disk brakes on it and replace the spindles. Is there a number on it somewhere? If it was in the middle of the axle it would be gone.If I replace the spindles how universal are they. Any help would be appreciated.
| | | | | Joined: Jul 2015 Posts: 18 New Guy | | New Guy Joined: Jul 2015 Posts: 18 | I replaced a 3600 front axle with 3100 axle for disc replacement job and axle part number was 3656872 you can check out my project page, about front axle replacement with discs, maybe it will help http://pin.it/Sdv5Mdp | | | | | Joined: Apr 2016 Posts: 1,037 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,037 |
