3 members (Tronman, Gib70, dt235sd), 126 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#1188750 10/29/2016 10:38 PM
I have a 53 3100. back in early the 80's I had a wheel bearing go out. At that time parts were hard to find and expencive. The 53 wheel bearing was many times more money than one a few years later. I had a newer front axle narrowed and bought bearings.The problem is that I have no idea what year it was. Now I am finally restoring it. I want to put disk brakes on it and replace the spindles. Is there a number on it somewhere? If it was in the middle of the axle it would be gone.If I replace the spindles how universal are they. Any help would be appreciated.
mick53 #1188925 10/31/2016 2:29 PM
I replaced a 3600 front axle with 3100 axle for disc replacement job and axle part number was 3656872
you can check out my project page, about front axle replacement with discs, maybe it will help
http://pin.it/Sdv5Mdp
winyrob #1189009 11/01/2016 12:45 AM
thank you
