5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#1188550 10/28/2016 1:59 AM
While spinning up the oil pump for a restart after a long spell I got to looking at the lithium looking grease in the reservoir and started wondering...
I have some 1/2" thick felt (organ servicemans gift) and decided try a 'looser' mix.
Wet the felt with MMM then worked 00' grease (steering box) into it, filled the cup 1/2 way added the wick then filled the rest of the void with 00.
My thinking is that it will flow better and not harden.
Any reasons other than possible increased maintenance to not try it?
Give me ambiguity
or give me something else
CASO #1188566 10/28/2016 3:15 AM
What year truck are you talking about? I'm trying to understand the "wick" part.
CASO #1188591 10/28/2016 5:46 AM
58 270 delco remi dizzy
I'll shoot some pics tomorrow to show. I haven't stabbed it back in yet.
Give me ambiguity
CASO #1188626 10/28/2016 6:44 PM
Here's the pics.
I suspect the felt is wasted space and will eventually just use the 00 unless I find it runs out instead.
Something about what was in there just didn't seem right...
DelcoRemy dizzy
Give me ambiguity
CASO #1188647 10/29/2016 1:31 AM
That distributor doesn't take a spring and a fiber disc like Chevrolet ones?
CASO #1188648 10/29/2016 1:33 AM
I would think that there would be a problem with using self-leveling grease for this application. I would think that the grease would seek its own level into the crankcase in short order.
CASO #1188658 10/29/2016 2:46 AM
Thats how I got it...minus a spring and disk I guess. That would make a more solid grease move which is what I was looking for...guess I'll do a little more retrofitting tomorrow I have springs and disk makeing material.
Give me ambiguity
CASO #1188687 10/29/2016 12:59 PM
ODSS Lawman
ODSS Lawman
Why not just get the correct type of lubricant as directed?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
CASO #1188691 10/29/2016 2:21 PM
Oh, c'mon Chris
Go with the flow, even though the called-for grease was not supposed to flow.
CASO #1189377 11/03/2016 8:56 PM
Mine didn't have the spring or fiber disc either. Part no places it as a 1952 270's unit. What size and strength of spring should it be?
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
CASO #1189416 11/04/2016 2:52 AM
GMC specs for 6-cyl distributors in 55-59 were to use S-2 (wheel bearing, not chassis) grease in the 6-cyl distributor cup.
SG (steering gear) grease (No. 0 grade, self-levelling grease) was used in the steering box (at the factory, and preferably when checking lubricant/grease level).
CASO #1189446 11/04/2016 12:41 PM
Ex Hall Monitor
Ex Hall Monitor
I had to use chassis grease in my '38 because bearing grease wasn't viscus enough. When I'd tighten the cup the grease would squeeze out around the threads. It's possible that I was just too heavy handed with turning the cup but it sure didn't seem like I was turning it too hard. The next time I reload I might do a "custom" mix of chassis & bearing grease.
CASO #1189451 11/04/2016 1:13 PM
I bet many people did/do this, because they might not have wheel bearing grease readily available.
