5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1188380 10/26/2016 9:26 PM
has anyone used any other type body mounts other
than the wood type that was used on my 1948
burb seems like some type of rubber would soften
the ride
thanks
Bob B
RoseB #1188417 10/27/2016 2:10 AM
We used rubber blocks on my uncle's 53 burb, not sure where he got them, I think it was either Classic Industries or Classic Parts. There were 2" (or so) square blocks and some thin rubber pads.
RoseB #1188509 10/27/2016 8:15 PM
My original blocks....52 Chevy Panel
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/100_0439.jpg
My new ones
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/NEWbodyblocks001.jpg
I had an old fire hose that had a layer of rubber and probably Polyester. It worked great as a 'cushion".
RoseB #1188510 10/27/2016 8:33 PM
RoseB #1188529 10/27/2016 10:35 PM
Here is a photo album showing 1954 Chevrolet Panel truck 1/2 ton mounting points with original blocks.
Panels 'N Burbs mounts are pretty much the same.
Maybe these guys can give you some insight. CPI TRUCK OR Dreamers Hot Rods -- Enlarged Photo
They have the below.
BED AND CAB TO FRAME MOUNT RUBBER BLOCK SET CHEVROLET GMC TRUCK 1947 - 1953
or
polyurethane square bar
You could cut it to what ever length you need.
But I would still use the rubber vibration Isolator Pads. Body Mount Pads - Panel, Suburban
HERE are some Universal Polyurethane Pads/Blocks
