2 members (1955 1 Series, Ole49GMC), 69 guests, and 5 robots.
Topics128,169
Posts1,057,102
Members48,463
#1188153 10/25/2016 4:50 AM
I am looking for suspension and brake parts for 1962 3/4 ton GMC ,lots for 1/2 tons there doesn't seem too much for 3/4 ton. Brakes and lines, front suspension parts . Anything local. Vancouver area?
1962 GMC 920 step side 261 4 spd
3B Offline
Hy GMC kid 7530, could you be more specific on what you're looking for? I do have a rolling 62 GMC 3/4 ton chassis.
I need to do some front end work,right side upper control arm shaft, I might need some ball joints, also will be getting into my brakes, will need shoes possibly wheel cylinders or rebuild kits. Do you know if any of the 3/4 ton and 1/2 ton suspension parts are interchangable.
3B Offline
Hy GMC kid 7530, a quick check of the parts book revealed quite a few suspension parts that are interchangeable between 1/2 and 3/4 tons. I would have to check specific parts to be sure, hope that helps.
I have had lots of luck getting older stock from NAPA. They even had wheel cylinders for my 49 truck (Huck style) in stock.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Moderated by  Gord&Fran
