| | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | I am looking for suspension and brake parts for 1962 3/4 ton GMC ,lots for 1/2 tons there doesn't seem too much for 3/4 ton. Brakes and lines, front suspension parts . Anything local. Vancouver area?
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GMC kid 7530, could you be more specific on what you're looking for? I do have a rolling 62 GMC 3/4 ton chassis. | | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | I need to do some front end work,right side upper control arm shaft, I might need some ball joints, also will be getting into my brakes, will need shoes possibly wheel cylinders or rebuild kits. Do you know if any of the 3/4 ton and 1/2 ton suspension parts are interchangable.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GMC kid 7530, a quick check of the parts book revealed quite a few suspension parts that are interchangeable between 1/2 and 3/4 tons. I would have to check specific parts to be sure, hope that helps. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have had lots of luck getting older stock from NAPA. They even had wheel cylinders for my 49 truck (Huck style) in stock. | | |
