| | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Did a 1946 2 ton have a glove box light option?
Was there a glove box light for the lighter 1946 Chevy trucks? Is it safe to assume if there was such an option they would fit in the 2 ton? Thanks. Jeffrey | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | We had a '46 1 ton pickup when I was growing up. There was no light in the glove box. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Keep us informed, nice addition to any truck.
Ed
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Unless I missed finding it, the Accessory Catalog doesn't show one. There is a coutesy light and switch below the dash center. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I'll look for that light and switch. Thanks Jeffrey | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | That switch on mine is actually a 3 position. The three positions on mine are right-light through the opening in the dash above the key/throttle/choke, center-off, and left-dash illumination when the headlights/parklights are on. The switch is located on the bottom edge of the dash, left of the ashtray, and the switch is a slide that moves through the three positions in a right-left direction facing the dash. Needless to say mine generally stays in the left most position so the dash lights work when I need them. My phone screen makes better light in the cab to find the key hole than the tiny bulb through that little opening above the key. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Check the Jim Carters Truck Parts catalog, I think I recall they might have listed the switch in the past year to two? The somewhat triangular shaped bracket used on the 1/2 ton models to hold the throttle and choke cables in place behind the dash, has a hole used to hold the light bulb. This info may or may not be the same for the larger trucks??? | | |
