| | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Does someone have the location and orientation of the VIN number plate for a 49' 3100. (filled rivet holes, don't remember) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Tim, Thanks, I have the new plate and rivets Still need to stamp numbers.
none of the links show a dimensional location from top or bottom hinge or orientation (facing in or out)
Need to mount for inspection,if I ever get that far.....
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | orientation is shown in my first link (between hinges) someone else will have to measure exact location your first post did not request code: codes are here what size/model truck? | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Tim, I have original tag, so I will copy numbers (NY plant ,July 49)
The pic looks like it is facing out towards open door
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | yes , all holes filled if I could get a measurement from floor from someone with a '49 3100
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Brad's picture gives you a great reference for where to put that plate. Just use the rib in the metal on the door to line up the bottom of the plate, then use your plate as a template to mark your 2 holes. Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Filled them with what? Weld or bondo?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Brad's picture gives you a great reference for where to put that plate. Just use the rib in the metal on the door to line up the bottom of the plate, then use your plate as a template to mark your 2 holes. Carl oh, should have noticed that,sorry Not sure how to use these rivets without pins,never saw those before Maybe will just use regular rivets
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like those those rivets were used from 1951 to 1972.
You punch the center of each rivet and that locks/secures the rivet/plate in place. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | OK, so a pin punch should do it now to stamp this plate consistently | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Not using original tag, if you have it, is fishy. It is illegal for you to stamp your own tag. If a savvy DMV guy sees a new tag, he should question the whole deal.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I use the techniques above for Coke machines and gas pump restorations, not trucks. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I know hacker is not trying to do anything wrong BUT: If you are legit, have the actual Title that matches an actual VIN plate for the actual truck, you are in like Flynn. There are rules in every state as to how to reattach the plate, get a duplicate or a new plate. Usually done by the DMV and/or State police. Just do that. Otherwise Bad things can happen. Then you have to prove what you did was "innocent" and pay a fine, a lawyer, impound fees, mend your handcuff sores and get an annulment of your marriage to Bubba. As you can obviously see, if what you are doing was allowed, any crook could buy a truck that was stolen, abandon, etc. and then buy a title that matches the year and make, then copy the VIN onto a plate and rivet it on. It's called Grand Theft Auto.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | There is no uniform pattern for the plates. Thanks for the pictures. I'm surprised at how amateurish the original plates look. I was thinking that it would be a good idea to get a trophy shop to engrave the plate but I think the final product would look too good!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | bartamos, I will check with Registry,this has been done before | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to keep your original ID plate in the truck, with the registration/inspection certificates (in the glove box, if you have one).
I wonder how many Stovebolters have had their original or stamped reproduction ID tag/plate (Vehicle Serial Number plate) inspected and/or challenged?
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | You might want to keep your original ID plate in the truck, with the registration/inspection certificates (in the glove box, if you have one).
I wonder how many Stovebolters have had their original or stamped reproduction ID tag/plate (Vehicle Serial Number plate) inspected and/or challenged? That was my intention to keep original in glove box, we will see what registry says
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Good deal. Glad you are checking. No offense to Government workers, but you can't trust the DMV, no way, no how. We, as the public, are so screwed up sometimes that we have made them squirrely and cautious. Not to mention they have rules to follow and there are no exceptions for nice people. Whomever has stamped their own plate is, so far, just plain lucky and/or lives in a state that is still civilized. There are guys at DMV who know what rivet is original or not. In AZ they don't see the truck, just the title. No emission inspection on older vehicles. We don't have safety inspections except OTR haulers and "special" vehicles.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I'll keep you posted as to their response.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Hopefully they say to set up an appointment with State police to witness you attaching old plate. The old plate is way more cool to have on there. Try hard to find some correct old clutch head screws or get them from some other place on your truck.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Post a parts-wanted ad for the clutch head screws.
I think you will find that style/size screw was not used elsewhere on the truck. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | wrong wrong
Almost as scarce as hen's teeth.
Those screws have a hex head as found/used on early clutch head screws. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just stand back and give me a few minutes with my bench grinder and they will be hex head. (A file or a sander will work also)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That'll do it - flat top and hex head. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I'm pretty sure I have the screws,sounds like it will be easier to put original plate back on .
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think the original plate is the right legal choice and they are cool. They can however be pretty rough and cleaning them usually does more harm than good. What we need is someone to develop an appliqué to recreate the original look on the original plate, hmmmmm. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | This ended up a long thread for a short question.
I really like the reproduction plate,nice and clean.
oh, well..... | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Remember at the end of the day it is your truck, it should really please you, not us. Plates and titles topics always drive that response, lots of opinions, horror stories and multiple states/countries of differing details. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Remember at the end of the day it is your truck, it should really please you, not us. Plates and titles topics always drive that response, lots of opinions, horror stories and multiple states/countries of differing details. Agree. I will say that whatever "patina" the plate has, against a newly painted jamb, is what makes it cool. Wash it, dab it with xxx and see what it wants to be cleaned with, depending what is wrong with it. Whatever it looks like, it's gold!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Hacker: lots of great advice here, I've been following this post and thought I'd weigh in. Just like you, Hacker, I had the original tag, but someone had previously removed it for cleaning and scratched it all up and it looked awful! I bought a new repop tag from one of the vendors: really nice! And so I went to a local engraver and impressed on him that I wanted the size and font of the engraving on the reproduction tag to match my original exactly. He starts talking about programming his engraving machine and how long it would take and $$$ and blah blah blah....and he could do it but it would cost like $160. Wut da h?! So after some serious consideration, my answer was to cut the corner out of my new tag and peel and stick it on top of my old one. My old tag is still on the truck then, right, but with a face lift. And sorry guys, I didn't use original type rivets or clutch heads....I did it my way, right? VIN TAG Good luck Hacker.....regards, Dave | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | All that proves is that you can do whatever you want until you try to sell it, register it, get new license plates and truck gets presented to DMV. What if you get in a fender bender and the police get involved? Try telling them you did it your way. Obviously I "don't care" but one can't escape that all this messing with VIN is Illegal. Whether you ever get "caught" or not. It's not debatable. All the ideas and aftermarket fabulous plates are all illegal. Some guy makes you prove it's your truck before he makes a plate, salesmanship hog wash and that will never save him if the Gov't/Postal Service comes after him. He ain't the DMV and none of us is either. I won't comment further. I respect that no one is trying to be illegal, just lazy or cheap. I can not believe you guys have the actual plate and are screwing around. Unbelievable. "Gosh all Friday" as my mother-in-law used to say.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | My 1953 had orig tag, but it was detached. Called for vin inspection, they ran engine #'s, and vin on title, they also ran previous title that was in So. Dak. When it did not show any irregularities the truck was signed off. I got aftermarket tag stamped my own numbers with Harbor frt. stamp kit. I am going to use orig. type rivits, ask the inspector about new plate install, was told it was OK to replace tag. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Remember at the end of the day it is your truck, it should really please you, not us. Plates and titles topics always drive that response, lots of opinions, horror stories and multiple states/countries of differing details. Brad, thanks | | |
