3 members (KEVINSKI, Cosmo, ShopRag), 91 guests, and 9 robots.
Topics128,187
Posts1,057,212
Members48,465
#1186269 10/11/2016 12:07 AM
Offline
I have a 1959 Chevrolet 235 engine that I am putting in my 1949 3100 pickup. The pan is in rough shape. Does anyone know where I can get a good used one, or a new one? I tried all of the parts outlets ( Jim Carter, etc.) but no luck. I don't know if the engine is from a car or truck, but it only takes 4 quarts of oil. There is no filter. I'm told that some of the car engines have a 4 quart capacity. The dip stick seems to be correct, however I would like some clarification. Also, does anyone have any leads on a oil pan??? Thank you.
There's one on Ebay right now but it's kind of rough looking and expensive. If yours isn't rusty or really badly dented, it will probably be better to try to work on the one you have. A lot of metal bumping, sanding and painting can be done before you start approaching the price of some of the parts buzzards. There's a big wrecking yard in Albert Lea Minnesota that scraps out a BUNCH of stovebolt stuff on Ebay- - - -they've probably got one.
Offline
Thanks for the information. I looked at the one on ebay, but it won't work for my 1959. That one is for a early 54, 55. It has too many partitions. My 59 is wide open. Mine is badly cracked around the drain plug. Someone tried to braze it already. Do you have the name of that junk yard in Minnesota or a phone number? Thanks again.
Try Alder's Antique Auto parts in NY
Salvage yard in Albert lea, minnesota is RPM MOTORSPORTS I think. phone number is 1-888-223-1864. I called them for one a while back and they were asking $125.00 for the pan. Good luck.
442.........email me about an oil pan for a 59 truck 235. You can't PM until you get 4 posts.
[email protected]
1959 3100 Apache Fleetside
Offline
Hi,
I am looking for an oil pan to fit my 1959 Chevrolet 235 engine. I believe it is from a car. Mine is damaged around the drain plug. Someone tried to braze it but it cracked again when I tried to straighten out the dents. My pan only has one flat baffle over the drain plug. The rest of the pan is open. Any help will be appreciated. Thank you.
Offline
You may get better results posting this in the Parts Wanted.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
I had a 'real' welder weld a new bung inside mine. He knew what he was doing. Even using my old HF blue POS. So rethink having yours redone by a true welder as they're not as lax by nature as 'someone'.
I had to CLEAN it throughout before he'd even begin and then he cleaned some more...
Give me ambiguity
or give me something else
