1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I'm gathering parts to put a 70ish 292 and MY6 transmission into a '68 gmc. I have the aluminum bell housing that was original for the transmission. I thought I had everything I need until I realized that there are no holes in the bell housing to mount the starter. [IMG]http://i305.photobucket.com/albums/nn214/jfnar/68%20GMC/IMG_01301_zps2qev0837.jpg[/IMG] In all the posts I've read about using the MY6 transmission I don't remember this issue being mentioned. Can someone tell me where I'm going wrong please? This is the last obstacle I have to clear before I install the engine. Thanks. Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Your 292 block should be drilled and tapped for a block mount starter.
Evan
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I would suspect that the starter would mount to the block the same as a small block V-8. The 292 should have been available with an automatic trans which would also mount the starter to the block. Fred
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Thanks for the info. Fortunately I have a '77 parts truck that has the right starter.
