1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | I have a 1959 Chevrolet 235 engine that I am putting in my 1949 3100 pickup. The pan is in rough shape. Does anyone know where I can get a good used one, or a new one? I tried all of the parts outlets ( Jim Carter, etc.) but no luck. I don't know if the engine is from a car or truck, but it only takes 4 quarts of oil. There is no filter. I'm told that some of the car engines have a 4 quart capacity. The dip stick seems to be correct, however I would like some clarification. Also, does anyone have any leads on a oil pan??? Thank you. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | There's one on Ebay right now but it's kind of rough looking and expensive. If yours isn't rusty or really badly dented, it will probably be better to try to work on the one you have. A lot of metal bumping, sanding and painting can be done before you start approaching the price of some of the parts buzzards. There's a big wrecking yard in Albert Lea Minnesota that scraps out a BUNCH of stovebolt stuff on Ebay- - - -they've probably got one. Jerry
| | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | Thanks for the information. I looked at the one on ebay, but it won't work for my 1959. That one is for a early 54, 55. It has too many partitions. My 59 is wide open. Mine is badly cracked around the drain plug. Someone tried to braze it already. Do you have the name of that junk yard in Minnesota or a phone number? Thanks again. | | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | Try Alder's Antique Auto parts in NY | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Salvage yard in Albert lea, minnesota is RPM MOTORSPORTS I think. phone number is 1-888-223-1864. I called them for one a while back and they were asking $125.00 for the pan. Good luck. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | 442.........email me about an oil pan for a 59 truck 235. You can't PM until you get 4 posts. [email protected]
1959 3100 Apache Fleetside
| | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | Hi, I am looking for an oil pan to fit my 1959 Chevrolet 235 engine. I believe it is from a car. Mine is damaged around the drain plug. Someone tried to braze it but it cracked again when I tried to straighten out the dents. My pan only has one flat baffle over the drain plug. The rest of the pan is open. Any help will be appreciated. Thank you. | | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | Thanks for the information. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | You may get better results posting this in the Parts Wanted. Samantha | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I had a 'real' welder weld a new bung inside mine. He knew what he was doing. Even using my old HF blue POS. So rethink having yours redone by a true welder as they're not as lax by nature as 'someone'.
I had to CLEAN it throughout before he'd even begin and then he cleaned some more...
