2 members (Woodcmiami, Mike Roache), 138 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1186199 10/10/2016 12:56 PM
1 Offline
Hello I removed a 4 speed from one of my parts trucks that I was thinking of using. The problem is I can not identify it. The number stamped in the rear case is RM46029. Looks to be a GM transmission from what I can tell. Any ideas on what I am dealing with?
It might help if we knew what year "Parts Truck" you removed it from and what engine was in front of it. Always include this info whenever you ask a new question. Don't just assume we know. Good luck in your quest. secret
Also, if you know, what rear end (or, if the rear end is original, or, non-original).
1 Offline
Good Point
Came out of a 53 Chevy 1/2 ton. 216 engine in front with stock diff.
Sorry for not including in post.
Riding in the Passing Lane
It should be a SM 420. There will be a torque tube from the rear end that attaches to the rear of it.
1972 Chevy c10 Cheyenne Super
1 Offline
I agree it should be an SM 420. It appears the truck this was removed from originally had a 4 speed transmission because it has the correct floor plate and the correct steering column.
I am trying to id the one I have because it works and could be a good transmission. I am thinking it is from a larger truck and could be older. Thanks for your help.
Take a look at the SM420 description at Novak Transmission. https://www.novak-adapt.com/knowledge/transmissions/manual/sm420/
