8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Got my clutch in the 59 but my idea for the trans lift hit the cross member before I was even in the pilot bushing... That 4sp is just too heavy to try to manhandle by myself.... Anyone diy one for their floor jack.... Just didn't want to throw the bucks at a store bought one if I can help it...any ideas? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Take the transmission hump section out of the floor. Usually held in with screws. Get two 4x4 lengths of wood that will sit secure on the floor board. Get two heavy ratchet tie downs straps and wrap them around the transmission and 4x4's and ratchet away until you can line up the transmission shaft with the pilot bushing in the crankshaft. Then shove the transmission home making sure you line up the locating pins on the bell housing.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Easier than ratchet straps is a shop crane stuck through the passenger door frame. | | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | I use an 8 foot 4X4 through the cab windows(doors open) and a cable come-along. It works better with the shift handle removed. On a 3 speed, just manhandle it- - - -not that heavy! Jerry
| | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | hmmm... Very interesting..txs for the input..maybe Been thinking bassackworth...a lift through the window would be great but no lift and worse yet no shop... One question..HRL why doors open? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have a roll around low scissors jack. I made a wooden seat that fits around the bottom and sides of the transmission. I just strap it on and use the jack for removal and installation. | | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | One question..HRL why doors open? I never think to bring all the tools I need into the cab with me! No fun climbing in and out of the windows! Jerry
| | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Yes sir... I got it right after I posted...long weekend. Thank you | | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | I built a wooden cradle for my t5 then used my motorcycle jack. Slick.
1954 GMC 9314 - 261 t5
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | This is a store bought one from HF that isn't too expensive. I think that I bought mine for $75 with a 25% coupon. Works great on the SM420 on my '57. http://www.harborfreight.com/450-lb-low-lift-transmission-jack-61232.htmlIt is make it easy to slide the tranny out of the way and then to spear the shaft into the pilot bushing when reassembling. The adjuster on the scissor lift lets you precisely adjust the shaft to the pilot bushing. Makes removing and installing an easy one man job. The only problem with it is that the tranny is so tall that you have to jack one side of the truck up very high to roll the transmission out from under the truck if you want to work on it. Matt | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I used to use a roller skate and scissors jack when I was young and broke.
Ed
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I manhandled my 4 speed into place, once. Not again! Hey Jerry, if you had a panel you could sneak out the back to get your tools. | | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Ty Matt..looked at that one... Think I'm gonna do a mini sawhorse with the comelong on top and the jack under to get the pitch right... Yes sir I know all too well about getting that tranny from under the truck!!! If this doesn't do it straight to HF txs
| | | | | Joined: Sep 2016 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 38 | Trannys in !!!! Txs to all you gentlemen with your ideas...this old girl is almost ready for paint. mazie
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 |
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Easier than ratchet straps is a shop crane stuck through the passenger door frame. I'm late to the party as usual but Cletis has nailed it. Due to a lack of room in my garage I actually took my engine lift through the drivers side door! First I pushed the transmission on a creeper to the rough position underneath the truck. I then fashioned two straps to cradle the trans., lifted, and with pilot pins in the top two holes of the bellhousing the put back was incredibly easy.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
