1 members (Truckrolet), 154 guests, and 2 robots.
Topics128,149
Posts1,056,818
Members48,456
#1184934 09/30/2016 9:44 PM
Considering putting a '41 4 speed transmission in a '37 1/2T.
It appears that the universal joint from the '37 will not mate with the flange of the '41 transmission.
Question: Is the output shaft of the transmissions the same? Will the flange from the '37 3 speed slip onto the splines of the '41 shaft?
Unfortunately, we do not have access to the '37 3 speed flange today. Hence the question. If they won't fit we have to begin looking at other options.
Thanks for your time,
Justin
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
Justin,
My '37 half ton project came with a 4 spd in it, an option for that year. You can make it work with the correct u joint assembly.
My '42 half ton has the same 4 spd in it and I blew the u joint, tearing up the yoke that attaches to the output shaft of the tranny. I had a heck of a time finding a u joint assembly for that application and during the process inadvertently bought a u joint that fit the 3 spd. The out put shafts are different as the 4 spd has a larger beefier diameter. I am guessing it will be the same for your situation.
Look at Keith Hardy's Old Chevy Manual site, find the correct u joint part number and keep checking Ebay or your other sources for old parts. I think you will find one eventually.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Justin,
Below is a link to a u joint on Ebay that will fit a 4 spd in your '37 truck.
http://www.ebay.com/itm/Universal-U-Joint-Assembly-1937-1938-1939-Chevrolet-Chevy-Truck-GC-HC-JC-/311711388353?hash=item48937252c1:g:VmMAAOSwAuNW7Q5m&vxp=mtr
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
' Offline
Bruce Bugay in Virginia has the U-Joint you need.
$99.00 plus shipping
GM NOS
GM # 5.584
GM # 600865
photos@photobucket with contact info
http://i669.photobucket.com/albums/vv57/glp0329/GM%20600865/GM_600865_b_zpsgempd3lm.jpg
http://i669.photobucket.com/albums/vv57/glp0329/GM%20600865/GM_600865_zpshgdeyuwr.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
