Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Rich'sToys, Hotrod Lincoln), 129 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#1184697 09/29/2016 2:27 AM
I am pretty sure I know the answer to this question but before I go buying the wrong parts I thought I would ask.
I am mating a 1966 283 with a 1987 SM465 transmission.
Correct me if I am wrong but I would use an early 168 tooth, 2 piece main seal flywheel with a later model clutch kit to fit the 35-spline main shaft correct?
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Use the flywheel and starter that came on the 283, then the clutch disk that matches the transmission.
Tommy
59 apache 1/2t
261 short stepside
Riding in the Passing Lane
It seems to me the SM 465 has the old style 10 spline shaft. You will need a bell housing to match the SM 465 as the center hole for the front brg retainer has a larger hole then the Sm420 or 6 cyl.
1972 Chevy c10 Cheyenne Super
Thanks guys, I think the early 4X4 SM465 had the 10 spline and then changed to the 32 spline on the later models. 2 wheel drives had the 35 spline. I was able to get the bell housing that came with the transmission. I will just need to find a part number for a 283 flywheel.
All SM420, SM 465 & G.M. versions of NVG4500 have 10 spline input shafts, are you sure the 32 & 35 splines aren't the output shaft?
BC
1960 C60 pasture art
Now that you say that you are correct. 10 for the input and 35 on the output. I had it backwards.
