1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | I am pretty sure I know the answer to this question but before I go buying the wrong parts I thought I would ask.
I am mating a 1966 283 with a 1987 SM465 transmission.
Correct me if I am wrong but I would use an early 168 tooth, 2 piece main seal flywheel with a later model clutch kit to fit the 35-spline main shaft correct? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Use the flywheel and starter that came on the 283, then the clutch disk that matches the transmission.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems to me the SM 465 has the old style 10 spline shaft. You will need a bell housing to match the SM 465 as the center hole for the front brg retainer has a larger hole then the Sm420 or 6 cyl. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Thanks guys, I think the early 4X4 SM465 had the 10 spline and then changed to the 32 spline on the later models. 2 wheel drives had the 35 spline. I was able to get the bell housing that came with the transmission. I will just need to find a part number for a 283 flywheel.
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Thanks guys, I think the early 4X4 SM465 had the 10 spline and then changed to the 32 spline on the later models. 2 wheel drives had the 35 spline. I was able to get the bell housing that came with the transmission. I will just need to find a part number for a 283 flywheel. All SM420, SM 465 & G.M. versions of NVG4500 have 10 spline input shafts, are you sure the 32 & 35 splines aren't the output shaft?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Now that you say that you are correct. 10 for the input and 35 on the output. I had it backwards. | | |
