Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Stovebolt48, Hotrod Lincoln, Lostbuthaulinass, UtahYork), 49 guests, and 2 robots.
Topics128,003
Posts1,055,242
Members48,418
#1184452 09/27/2016 4:55 PM
OK guys, I can't for the life of me find out the HP or anything on my newest project, the '72 Sprint.
The code stamped on the pass. side of the block is V0701HV. any info? It also has 416 heads on it.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
It could be a 1965 327 or a 1969 350. The telltale sign is the journal size. The first year of large journal 327 is 1968, therefore, if the journal is small, then it's probably a 327 and if the journal is large, then you have a 350. The 327 would be a 350hp 327 and the 350 would be rated at 255hp. If you had the original cam and it was a 327, that cam would be a little radical, with almost 0.450 lift and would sound much different than a 255hp 350. What is the casting number on the back of the block?
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
Well it's still in the car, so I can't really get to the back of the block to check. And by journals, you mean the crank journals, right?
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
OK, so I was able together the numbers off of the back of the engine, they are: 3956618
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
69 -302 Z28
68-69 327 2 bolt main
69 -350 2 or 4 bolt main.
secret
The 1968 & 1969 Z/28 302 will have a suffix code of DZ (one of Chevrolet's most recognized suffix codes, belonging the the large journal high winding 302), both the 68 & 69 327 will be large journal. Since the HV suffix code matches 350 and the casting code resembles a match to the 350 (250 hp), you probably have 350. Don't know if it's 2 or 4 bolt main, but IMHO, the 2 bolt main engine is preferred for building a performance engine, as it is much easier to drill the 2 bolt main block for use with nodular iron 4 bolt main splayed main caps (GM part number 14011072) and the block webbing of the 2 bolt main block are beefier than its 4 bolt main counterpart.
