Brrrr
place holder
0 members (), 136 guests, and 2 robots.
Topics128,274
Posts1,058,431
Members48,489
#118421 11/08/2005 12:39 AM
Okay it's winter here and I'm working on the doors and trying to take the inner latch and window mechanism out. I've tried penetrating oil and the large flat screws won't budge. Is there a trick of the trade to get them off or should I heat them and try it. I don't want to strip them as there a rare commodity around here. Enjoy the sight and I get lots of info from it. Bob T
#118422 11/08/2005 12:47 AM
Heat works great ,but before that ,put your screwdriver in the slot with some presure,and give it a nice firm blow with a fairly large hammer,four pound is my favorite.this can loosen the thread's.if it don't werk HEAT IT!!!! grin
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
#118423 11/08/2005 1:14 AM
bobt,
No self respecting man from Moos Jaw would get caught without a impact driver. They have a handle, assorted bits and you blast em with a "fairly large hammer". grin
Stuart
#118424 11/08/2005 3:00 AM
I heat them cherry red and spray them with water immediately. The impact driver works good after that but I've never seen a clutch head driver large enough for the door screws. Those are the single hardest screws on the truck to remove.
#118425 11/08/2005 11:51 AM
Another thing that worked for me...turn the stuck ones in first and then out...
#118426 11/09/2005 6:41 PM
Thanks for the info, I used penetrating oil, let them sit for a few days and then took the screwdriver and put it on the edge of the screw and pounded them counterclockwise. It broke the seal and they all came off. Thanks again.
Bob T
