2 members (2-Ton, MikeE),
86
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Okay it's winter here and I'm working on the doors and trying to take the inner latch and window mechanism out. I've tried penetrating oil and the large flat screws won't budge. Is there a trick of the trade to get them off or should I heat them and try it. I don't want to strip them as there a rare commodity around here. Enjoy the sight and I get lots of info from it. Bob T | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Heat works great ,but before that ,put your screwdriver in the slot with some presure,and give it a nice firm blow with a fairly large hammer,four pound is my favorite.this can loosen the thread's.if it don't werk HEAT IT!!!!  | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bobt, No self respecting man from Moos Jaw would get caught without a impact driver. They have a handle, assorted bits and you blast em with a "fairly large hammer". Stuart | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I heat them cherry red and spray them with water immediately. The impact driver works good after that but I've never seen a clutch head driver large enough for the door screws. Those are the single hardest screws on the truck to remove. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Another thing that worked for me...turn the stuck ones in first and then out... | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Thanks for the info, I used penetrating oil, let them sit for a few days and then took the screwdriver and put it on the edge of the screw and pounded them counterclockwise. It broke the seal and they all came off. Thanks again. Bob T | | |
