2 members (Bucker, latroca52),
111
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Either could be original. I'd look for two more 22.5 wheels and run modern tubeless radial 9R22.5 tires all around. Your bolt pattern is 6 lug Budd | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | Ok thanks for the help Grigg. jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy jf1947, I think your front wheels may be Firestone RH5 widow makers, please be very careful when working with or around these wheels. Do not do anything with these wheels until you totally deflate the tire, removal of the valve core is the safest way to make sure there is no pressure left in the tire while working to take these wheels apart, hope that helps. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I agee with 3B, your front tires are 8.25x20 which means they are tube type and are mounted on some sort of a split/multi piece rim. The 22.5 are all tubeless one piece rims and are the direct replacement for the 20" rims. You want to replace your front wheels and tires asap with 9.00x22.5 tires which is the same size as your 8.25x20. Mike B  | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | Thanks guys for the info. I am going to put the front end on Jack stands & deflate the front tires just to be safe. I'm planning on ordering a set of the accuride 28157 along with new tires. jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Do you have six lug or ten lug wheels? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks guys for the info. I am going to put the front end on Jack stands & deflate the front tires just to be safe. I'm planning on ordering a set of the accuride 28157 along with new tires. Let us know if they are still available new, and cost...good info to know. | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | Txpete, I have the six lug front & back. I will be sure to let everyone know what I find out from wheels now. jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Do you have six lug or ten lug wheels? | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Are they budd style wheels. ? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Are they budd style wheels. ? his pictures show 6 hole Budd wheels. | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | Txpete sorry for the no response I thought I replied, yes they are six lug. I heard back from wheelsnow and they do have the accuride 28157 in Stock for $225 a wheel. Yes its expensive but it solves my problem. Tried locating a used set but no luck.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds about right for a brand new wheel. Consider a used wheel might cost $10-20 for tire removal and disposal. Then another $75-120 for blasting and powder coating. On top of purchase price which might be $50 plus or minus. | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | I bought six nice modern one piece rims today from a guy in Houston tx who runs salvage parts business. The only new ones I found to replace my widow maker 20 by 8.5 center split rims RH5s ( extremely dangerous ,,,please don't even put air in or out of those ). We're 240.00 from a company called wheel snowing.com The guy I bought from runs his dad's old 60 yr old salvage parts business. He says he may have a source for more of them. They came off fed ex van truck . If you want his contact info he said I could share it. Or search for ...Art's Auto Parts Houston Tx on McCarty St. Pete | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | So, what size are your new wheels, 19.5 or 22.5 ??? Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Also consider the width of the new wheels relative to the tires you want to run. 6" wide works well with 9R22.5 tire 7.5" wide could still work fine or might not fit as well on the vehicle. | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | The new wheels would be 22.5 x 6.75 the salesman said a 9x22.5 tire would be a good fit. As far as the rear, it already has solid wheels with old 9r22.5. I would like to go with a little taller tire in back to compensate for the gears. How does that sound? Thanks for everyone's advice jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Just check width of your rear rims and compare to recommended width for the larger tire you want. | | |
