0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I was just given the polisher but the foam pad on the unit is gone. There is just a disc with glue residue on it. How do I get that disc off? I tried to lock it in place but that does not work. It must come off because I see screws underneath the disc. Thanks | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | If I had it here, I could look and tell you. Hopefully someone will have an answer for you. Otherwise, I will look at mine when I go back to work on Tuesday. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Well, my polisher/sander is a 6". It has a slot for putting a locking rod in. I'm going to guess, since it has that, that the disc unscrews from the shaft. | | |
