4 members (68ironhead, Peggy M, Jon G, Shade Baby), 106 guests, and 2 robots.
Topics128,117
Posts1,056,298
Members48,439
#1182940 09/16/2016 11:45 PM
I was just given the polisher but the foam pad on the unit is gone. There is just a disc with glue residue on it. How do I get that disc off? I tried to lock it in place but that does not work. It must come off because I see screws underneath the disc.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
If I had it here, I could look and tell you. Hopefully someone will have an answer for you. Otherwise, I will look at mine when I go back to work on Tuesday.
Well, my polisher/sander is a 6". It has a slot for putting a locking rod in. I'm going to guess, since it has that, that the disc unscrews from the shaft.
Moderated by  MNSmith
