Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, 55shaker, 2 invisible), 117 guests, and 2 robots.
Topics128,292
Posts1,058,598
Members48,492
#118406 11/06/2005 3:46 AM
I just mounted my cab back on the frame. A local guy repaired the cab with new cab corners and a floor pan/toe board panels. I am trying re aling the brake pedal, but he hole is about a quarter inch lower than the pedal...my question is whether it is best to shim up the cab to create alignment or to enlarge the pedal hole to make the fit??? I think a quarter inch shim on each side will do the job, but will this mess up the alignment of the fenders?
Thanks, Mike
more likely you'll find you hack the holes, then later hafta shim the cab to get the front to fit!
be best to make sure the cab is properly positioned and mounted, and loosely fitting the front metal will help w/ that
Yeah, Like Red said, I would fit the front parts THEN deal w/ the pedals. Just MY2¢
I don't know what truck your working on, but if it's an AD, do you have the rubber pad between the frame and cab support? It's about a 1/4".
The factory assembly manual does have specifications for cab height off the frame rails. I would make sure that the cab height is within spec and then adjust the holes in the floor boards as necessary. I am in the process of installing after market floor boards in my truck and they definitely need to be modified to make them work correctly. I had to drill many holes and add metal in other areas, but I have not even tried to see how the pedals are going to fit yet.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
