8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#1183955 09/24/2016 1:05 AM
Found a replacement hood for my 59 truck, only thing is one one the hinge mounting holes is wallowed out... Tried chasing it with a tap but it will not hold the bolt... Is there enough meat there to helicoil or should I try to weld it , drill and re-tap?
Mazie 59 #1183957 09/24/2016 1:19 AM
Use a thread repair method called a "Riv-Nut" It fits into a hole drilled oversize and is installed with a plier-type tool similar to a pop riveter. Harbor Freight, Northern Tool, and similar places sell then, plus they're available on Ebay. It's a quick, easy, and permanent fix.
Mazie 59 #1183962 09/24/2016 1:31 AM
Excellent... Txs much
Mazie 59 #1184014 09/24/2016 4:46 AM
Depends on thickness, helicoil for thicker, riv-nut for thin stuff.
1952 Chevrolet 3800 pickup
---All pictures---
Mazie 59 #1184039 09/24/2016 4:26 PM
Heli coil would do a good job for sure but maybe you could go one size bigger bolt? Or try tapping a fine thread same size bolt? Maybe a metric bolt is just a tiny bit larger and tapping it would provide a solution?
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Mazie 59 #1184092 09/25/2016 12:34 AM
Thanks for all the suggestions...will dig in tomorrow
Mazie 59 #1184796 09/29/2016 10:19 PM
Insomniac
Insomniac
How did you make out with this problem? I have the same issue. It looks to me that the riv-nuts are 5/6-18 NC thread, but the special hood bolts are 5/16-24 NF threads. frown
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Mazie 59 #1184821 09/30/2016 12:56 AM
I'm sorry Gord, I dug in alright but since I didn't have time to get by Northern, I jumped on the clutch.... I will check but I could swear the hinge bolts on my 59 were 5/16 x18... Very possible I'm mistaken...I'm a woodworker not a mechanic! Will post how it works out... Good luck on yours
Mazie 59 #1184834 09/30/2016 1:58 AM
Pegasus auto racing has 5/16-24 rivnut and an economy insert tool in case you only have a few to do
Mazie 59 #1184837 09/30/2016 2:12 AM
The installation tool isn't really a necessity- - - -just use a bolt, nut, and flat washer to install the riv-nut. Anything to squeeze the rivet section out against the hole works- - - -the plier tool just makes it quicker to install a bunch of 'em.
Mazie 59 #1184842 09/30/2016 2:36 AM
Insomniac
Insomniac
Thanks. I see that Fastenal has them - but maybe not at my local store. I hope they can get some for me without having to order a thousand or something...
Gord 🇨🇦
Mazie 59 #1184873 09/30/2016 11:00 AM
I am not sure about your particular situation, but one of these plug welded to the sheetmetal may work for you if the riv-nut doesn't.
http://www.mcmaster.com/#weld-nuts/=14e3mzn
Lots more pictures
