| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I have a 1950 3100 that I just finished putting the driveline back on the frame. The only sheet metal on the frame is the cab.
I'm wanting to install the radiator temporarily so I can drive the truck around a bit before I put the front clip back on. Hoping to take care of as many issues I can before things become more difficult to access. Looking for some ideas, plans or suggestions to accomplish this task.
Jackie | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I suggest you spend some time searching wrecking yards for at least a radiator and core support so you can drive it, you might have to get a whole truck, for all the bolts, fittings, etc.
Ed
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Can you use your radiator core support and run a rod from support down to the chassis? | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | There are two long rods which go from the top/front of the radiator support and the lower radiator baffle (the one which the grill sits on). Put all of those parts on and you can drive to Maine.
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Is this picture of Deves truck what you are describing? Only difference is my cab in on the frame and I do not have the radiator on it yet. I only want to scoot around the parking lot a little bit to confirm no really big issues are present. Jackie | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | No. Those rods in Deve's pics are welded on. The ones you need are bolted on the radiator support on the sides near the top, and to the lower radiator baffle. Many times these get left out by mechanics.
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | We found the support rods!! Just a few loose ends to tie up and it will be ready for a short test drive....... | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | They are often mistaken for rear fender braces, just too long.
