2 members (Hotrod Lincoln, Gdads51), 76 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#1182659 09/15/2016 12:35 AM
I have a 1950 3100 that I just finished putting the driveline back on the frame. The only sheet metal on the frame is the cab.
I'm wanting to install the radiator temporarily so I can drive the truck around a bit before I put the front clip back on. Hoping to take care of as many issues I can before things become more difficult to access.
Looking for some ideas, plans or suggestions to accomplish this task.
Jackie
Crusing in the Passing Lane
I suggest you spend some time searching wrecking yards for at least a radiator and core support so you can drive it, you might have to get a whole truck, for all the bolts, fittings, etc.
Ed
Can you use your radiator core support and run a rod from support down to the chassis?
There are two long rods which go from the top/front of the radiator support and the lower radiator baffle (the one which the grill sits on). Put all of those parts on and you can drive to Maine.
52Carl #1182830 09/16/2016 12:01 AM
Is this picture of Deves truck what you are describing? Only difference is my cab in on the frame and I do not have the radiator on it yet. I only want to scoot around the parking lot a little bit to confirm no really big issues are present.
Jackie
No. Those rods in Deve's pics are welded on. The ones you need are bolted on the radiator support on the sides near the top, and to the lower radiator baffle. Many times these get left out by mechanics.
We found the support rods!! Just a few loose ends to tie up and it will be ready for a short test drive.......
JackieC #1183033 09/18/2016 12:56 AM
They are often mistaken for rear fender braces, just too long.
