4 members (Gray_Ghost, DadsFirstPickup, TUTS 59, 1 invisible), 71 guests, and 4 robots.
Topics128,089
Posts1,056,364
Members48,442
#1182419 09/13/2016 4:04 PM
A guy on craigslist has a Dana rear axle from an 84 1-ton. I asked for the distance between spring perches and he said it's 40", center to center, which is what I measured on my '57 axle. Does anyone know if there's any reason that this axle won't fit under a '57? He's a couple hours away so I'd like to know if it'll work before making the trip. Thanks for any advice.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #1182437 09/13/2016 6:14 PM
Chances are good the axle is wider where the wheels mount than what you have, making for a wider stance.
If you've checked that and it's not a problem, or you're not worried about that anyhow then it will fit or can be made to fit.
If by chance one of you measured wrong and the spring pad center distance is not the same it's not the end of the world if you have to relocate them.
Have you researched and shopped for a GM 14 bolt rear axle? In my opinion they make a great swap for a 1 ton axle, cheap, easy to work on and get parts, and good selection of gear ratios.
•1952 Chevrolet 3800 pickup
---All pictures---
jfnar #1182442 09/13/2016 7:33 PM
Crusing in the Passing Lane
Second on the GM 14 bolt, ff.
Ed
jfnar #1182459 09/13/2016 9:02 PM
What models and years of trucks would have the 14 bolt rear?
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #1182460 09/13/2016 9:29 PM
lots of info (but not everything) here.
http://www.pirate4x4.com/tech/billavista/14b_bible/
---All pictures---
jfnar #1182507 09/14/2016 1:09 AM
I pulled one out of a 93 Suburban, it was 67.5 wide but I have a single rear wheel 1-ton flatbed so the slightly wider stance is fine. I have found 63.5 under a 73 chevy C30 flatbed.
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
jfnar #1182618 09/14/2016 7:14 PM
They are pretty easy to spot on the road to get a good idea of what they came in, look like someone took a bite from the bottom right corner.
ED
Moderated by  Dusty53
