4 members (Maybellene, klhansen, 2 invisible),
87
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | Hood alignment...oh god. The front is okay. The cowl (back end) is pretty much okay too. The sides are a problem. One side is okay. But the other (left side) has a big gap between the fender and the hood. Don't know what to do. Thinking about taking it back to my good (very expensive) body/paint man. Is there any hope? I have everything (grill, radiator support, lower cowl) tightened down. I hope there's hope. I read a post awhile back how some guy shows his truck with the hood up...just because of this. | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Had the same problem. My hood hinges were worn. If you take off the hood springs it might sit right. My springs were pushing up on the worn hinges causing large gaps @ the back of the hood. I just left em off (the springs) & got a rod to prop it up when needed. I'll put some new hinges on when I get arountuit. Also, check the hood to cowl seals. Sometimes they crack & get out of place. That will hold the hood too high also. Get that thing in the Gallery will ya  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Kevin, If you have not see the article on Hood Alignment on Chevytrucks.org by Mac Kinghorn, you might want to check it out. I still don't have my Suburban's hood right (it is not touching the cowl seal). Just got to keep tryting, I guess. Tim | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I have found the hood fit never was the greatest even new from the factory. I swear if I didn't take it apart I would think all the stuff was from different trucks. With enough time and patience you can fit it up respectfully. To get my hood down on the cowl seal I had to shim the center brace with washers, it pulls the center down. I had to shim my inner fenders where they bolted to the radiator support to gain width for the hood at the front, then with every thing loose at floor bolts you can really move the front around with the cowl brace rods. I did have new hinges and new deluxe outer cowl panels which go from bottom to lead seam. Look here http://community.webshots.com/user/zeker6 Zeke (Put lots of tape down to protect the paint while fitting.)
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Oct 2005 Posts: 4 Junior Member | | Junior Member Joined: Oct 2005 Posts: 4 | You might try loosening the fender bolts up and moving them in or away from the hood as needed, if you cannot get any movement out of them you may be able to slot out the holes a little larger only if needed. | | |
