1 members (joe apple),
79
Mod | | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Lucille just hit a "performance home run"!! Knocked it out of the park after all these years of listening to you folks here on the Stovebolt!! I am so very excited! She has never run this well and I thank all of you who have given me great advice over the years!
So, to sum it up here's what all came together in order for her to perform so well.
Parts that are new or rebuilt:
Carburetor - Rebuilt Carter W1-574S New Fuel Pump w/Glass Top Fuel Filter New S/S fuel lines New S/S Vacuum Advance line New Gas Shut Off Petcock Gasoline is totally Ethanol Free Added Seafoam to fuel to help dry out any moisture in tank Set timing with a timing light. Ball bearing on flywheel dead on. Timing advance is 5 degrees above TDC At 180 degree engine temperature RPM's are 600 Backed out idle screw 2 1/2 turns.
Just got back from running Lucille for 42 miles! Longest smooth run she has ever done with no hesitation and no back firing. She climbed hills with no need to down shift. Just put the pedal to the metal and she powered right up any hill like I've never seen her do.
Had to celebrate by stopping at a bar to have a beer. Half hour later got back in Lucille and she fired right up with no problem at all and gave me a great ride home!! I am so pleased after all this time of trying to get her to run right. Now I can say "I've got a good running Stovebolt"!!
Now it's on to more cosmetic issues that I can nit pick on.
Once again, Thank you all for such wonderful support! I could not have accomplished this without all of you out there!!
David
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | that is great news! It is a good feeling to have a good running bolt! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Congrats David. I know "Lucille" is like a new gal now and I'll bet Pam would agree that your much easier to live with. LOL Come see us. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Thank you Alvin!
Remember our first meeting at "The Junction"? A great meat and three place, however, it didn't match a chilly dog and Pepsi with you!!
Your awesome and you have taught me a lot!!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Congratulations........but..........you purchased ethanol free fuel ( likely paid extra), then you add Seafoam which has alcohol ( IPA 10-20% by weight) in it............everything else makes sense.
Seafoam the rest of the can........ Pale oil 40-60% by weight Naphta 25-35% by weight
Per MSDS
| | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Thank you showkey!
The Seafoam was just a one time thing because I've had gas with ethanol in Lucille for several years and the accumulated condensation of moisture in the tank, which was mostly half full all the time, was questionable. Also Lucille sat a lot and did not run for a number of years while we were moving from one State to another. I don't believe it hurt her at all.
The ethanol gas is more expensive but I don't care about that. Three plus dollars a gallon is OK for me on a 70+ year old antique truck which brings her back to life and is not a daily driver!! She's a Stovebolt Calendar Girl from 2009! Awesome!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | I love a happy ending! My career was in the fuel business. Ethanol was destructive to all our pumping and storage systems. It's hydrophillic - attracts moisture out of the air. That's why it can't be used in airplanes - it causes intake icing. Sources for non-ethanol fuel can be found at: http://pure-gas.org/ | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Congrats David. Your enthusiasm I'm sure has inspired many Bolters to run back to the shop and wrench a little more. I hope to join the "It's Alive...Finally!" Club in a year or two! Enjoy that "new" found ride! | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | David,
What was the actual issue? Was it the coil, points, condenser, or timing?
Happy to see you are back up and running.
Paul | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Thank you PaulWNC,
All of the above plus more!
The old coil was one of the major problems. Timing was an issue and so was points and the condenser which I accidentally shorted out. Finally the carburetor was the last adjustment I had to get right. I adjusted the throttle RPM's down to 600 RPM and opened the idle screw until I was getting a smoother reading on my meter. Getting a smoother idle reading was an excellent tip offered by Jerry (Hotrod Lincoln).
There will me more things to do with Lucille, but for now I'm just so pleased that she finally runs so well.
Oh, another thing, you've got to let these old trucks warm up to operating temperature first before monkeying around with all these settings. And also get her warmed up before driving. Ya can't be in a hurry.
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Jesse Z,
Great link to find ethanol free gas!! These old trucks do not run well on ethanol gas, period!
Thanks on your comment!
David
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | My '53 235 runs fine on 10% ethanol, other than the fact that every 18 months I have to replace the accelerator pump diaphragm in the Carter YF carburetor. Carl
