8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck), 87 guests, and 2 robots.
Topics128,202
Posts1,057,409
Members48,471
I'm installing the bed wood on my 57 and am wondering if anyone has any good suggestions on how to get the nuts started on the bolts that are up inside the bed crossmembers. There's not enough room for my fat fingers and I've tried putting masking tape on the end of the socket then putting the nut on the masking tape. That sort of works, but try putting a flat washer and lock washer on top of the nut and it becomes very frustrating. Would sure appreciate some "tricks of the trade" on this. Thanks, Don
Bought a set of magnets that fit inside the sockets, 6 for about 3 bucks. auto parts store.
Magnets don't work on Stainless Steel. What ya need is that Gnome from the Travelocity commercials. (He's got little fingers) grin
Try a nut driver with some spray on contact cement to help hold the washers in place while ya start em. If the nut driver is too deep, put 2 nuts in. Good luck. smile
Anonymous
Unregistered
Anonymous
Unregistered
Texas Aggie Solution: Hold the nut in place and spin the bed.
Shipwright,
Just for the record, all stainless isn't non-magnetic. wink
Stuart.
I used Dum-dum, or what is known also as 3M strip-calk, a black sticky rope-like pliable sealer used to seal holes in auto bodies. Stuff some in the socket, holds real well. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks for the ideas, I have 3 of my friends coming over today, one will hold the nut while the others spin the bed. Sounds good to me. There's always a solution out there somewhere. Don
Sounds like you need someone to hand out beers and take pictures.
I'll be there in an hour to *help*.
mark.
'51 KY 3100
Blue painter's masking tape, for those hard-to-reach ones. I have a '53 shortbed, but encountered the same problem. Small pieces of tape, to tape together the flat washer, lock washer and nut. Then very carefully starting it all with a socket. And don't drink too much beer.
