4 members (66flea, cmayna, Shaffer's1950, Wally / Montana), 106 guests, and 1 robot.
Topics128,154
Posts1,056,838
Members48,456
#1180187 08/28/2016 8:56 PM
I am looking for help with putting on a new hood to cowl seal on my 1941 Chevy ak truck. I believe I have the correct replacement but unsure about attaching. I have no pictures or 41's nearby to look at. Anybody have any illustrations etc.
41fan #1180210 08/29/2016 1:14 AM
You might re-post this in the body shop area of the forum. Maybe some guys there who do a lot of body work are accustomed to those particular seals....(or maybe they can direct you better than I).
41fan #1180356 08/29/2016 9:32 PM
Ok, the 41 and 46 are the same here. The cowl seal is either rubber or cloth about 3/4" wide and 1/4" thick. There is an indent in the cowl where the seal goes. You will also need the clips that hold the seal to the cowl. Screws go through the seal and the clips into the body at each rounded indent on the cowl. There should already be holes for these screws. There 4 on each side. The seal starts in the middle by the hood hinge across the top of the cowl and down the side.
Check out some of the vendors, they may have an illustration of how the seal is attached.
Hope this helps.
George
Thanks George, I just had it painted and I am not seeing any holes but they could be covered with putty/paint. I bought the seal from Chevs of the 40s with six clips and no info.
41fan #1180576 08/31/2016 5:26 AM
Maybe THIS will help.
Harold
Harold
Harold, thanks a bunch for the photo, that was perfect. I was able to install one side and it looks great. Now it's time to put in another order to Chevs of the 40s for a bag of clips. Much appreciated.
41fan #1180696 09/01/2016 1:10 PM
Ex Hall Monitor
Ex Hall Monitor
I was wondering how similar the cowl lace was to the '38. The '38 had those clips just at the ends with a "J" hook between.
J hook.
End clip.
41fan #1180717 09/01/2016 3:48 PM
Tina,
Maybe the hook was used due to the "lip" on the cowl lace in 38. The lace on the 42-46 is flat thus the clamp. Just a guess on my part.
Harold
Harold
