1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 23 | On a 49 3100, are the front parking lights the same as turn signals? My truck has neither.
Rais'em from the dead.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | On an original truck they will be parking lights. Unless a previous owner has added a turn signal kit they did not originally come with your truck. Those kits back in the day usually included or were used with something like this. https://www.flickr.com/photos/advance-design_parts_co/8130552846/in/album-72157631870734114/There was a wide variety of aftermarket versions available and accessory Guide models that could be used. I chose to eliminate these and bought sockets for my original parking lamps to convert them to turn signals. http://www.classicparts.com/1947-59-Double-Contact-Conversion-Kit/productinfo/47%2D905/ | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I made mine both. I put in yellow LEDs for turn and white LEDs for park. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Yep. How I added the dual contact socket for turn signals on my truck. Clear lens and yellow bulbs. 1157 lights and all was good.
Steve H
| | | | | Joined: Mar 2012 Posts: 7 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 7 | I am installing the two contact lights from classic parts, does it matter which wire I use for parking or turn signal? | | | | | Joined: Jan 2016 Posts: 1,107 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,107 | I could be wrong, but take a close look at the bulb. I think the filaments are different. One is thicker than the other one. If so, I think the thicker one is your turn signal. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1949 Chev truck wiring diagrams shows stop (white) and tail (black) and both 16 gauge wire. http://chevy.oldcarmanualproject.com/electrical/wiring/index.htmThe bulb goes in one way. Maybe someone know which filament is the larger/brighter? On the rear, those two filaments served as parking/marker/driving and brake light. I forget which one was used for turn signal. | | | | | Joined: Jan 2016 Posts: 1,107 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,107 | The brake and turn are the same filament. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The brake and turn are the same filament. That would depend on what type of signal switch is used. | | |
