0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
I was given a 1945 Chevy 1/2 ton rolling chassis and the wheels did not want to turn easy.
So I took off the front drums first and backed off the brake adjustment then quickly cleaned the bearings and repacked them.
Then I took off the rear drums and backed off those brakes. While doing that I noticed that on the rear axle flange that the brake drum rests against there was a paper gasket that fit over the wheel studs.
Was that gasket factory?
Is gasket needed?
Why would there be a gasket used there?
Thanks Jeffrey
I think you will find a special hole in the flange that drains the oil slinger on the inside. This supposedly drains off fluid that gets past the seal. The drum has a matching hole and they should line up. I would think that the gasket completes the design. Personally I think the setup will not stop fluid from getting on the shoes but that is just my opinion.
1951 1 Ton Completed
"Then I took off the rear drums and backed off those brakes. While doing that I noticed that on the rear axle flange that the brake drum rests against there was a paper gasket that fit over the wheel studs."
I've heard a couple different opinions...and mine is that it was to keep the drum from rusting to the axle!
Riding in the Passing Lane
The quality of the seals back then were not very good. They had slingers on the backing plate to send the leaking grease outside the brakes. The gasket was to keep it from seaping between the axle & drum. The gasket is not nessesary now with modern seal technology.
1972 Chevy c10 Cheyenne Super
I would tend to agree with this because this gasket will do nothing to keep any oil getting past the rear axle seal from getting onto the brakes.
Thanks for the answers. Jeffrey
