7 members (55shaker, Tim Canfield, moparguy, Hotrod Lincoln, Gdads51, Bill Hanlon, treegrower),
132
0
Mod | | | Forums66 Topics128,195 Posts1,057,380 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 |
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is there an ID tag/plate on the cab between the driver's side door hinges? If so, post the code or a photo of the tag/code. 1951 rear dual wheel models are shown here It looks like 5 bolts on front tires and 10 bolts on dual rear tires? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Looks to be a very nice 4000 or 6000 series truck, the data tag serial number and GVW will tell the story. | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | I don't have access to any of the other tell-tale identification features of this '51 chevy. The truck is 500 miles away, and is for sale. The owner hasn't supplied enough info other than these mediocre pix. I do not know enough about big bolts to even venture a guess. I was hoping some one could ID it by lug patterns/number, wheel style, differential pix, etc.....I'll see if he can get me a pic of the ID tag.... Thanks
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | What is the owner calling it? Looks like it could be a 4100. A lot of 4100's were made into "Wheat Trucks".
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It is some sort of 1.5 or 2 ton, looks like 7.5 or so, 20" tires. Since is inside, should be good, how much does he want?
Ed
| | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | It is some sort of 1.5 or 2 ton, looks like 7.5 or so, 20" tires. Since is inside, should be good, how much does he want?
Ed I'm not sure what a 7.5 is, Ed. What is that???? I'm not sure how much he wants. I'll let you guys know when I find out and see if it's a fair price.... | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | What is the owner calling it? Looks like it could be a 4100. A lot of 4100's were made into "Wheat Trucks". He's calling it a "grain truck," Martin.... | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | here is a 6400 2 ton grain truck, front wheels similar, cant see back wheels good enough to compare, has similar red wood, just not as high up on your photo
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | I bet that's it, Joker....a 6400 2 ton.... Man, that's a LOT of truck.... | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | would go good with your little green truck, what part of Tx is it located? are you a serious buyer? you might pm member HI . I got the pix from him he is still active on the bolt, he could probably tell you a lot if it is the same type truck and looks like it is close enough
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | It's up in the panhandle, Joker...Yeah, I'm a serious buyer, but he's not responding to emails... I think I'm a more serious buyer than he is a seller... I'm near San Antonio...Where are you? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Can't tell for sure, but looking at the front dust/grease cap, looks like it bolts on, which would make it a 2 ton. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | roger that Madd, a long way from you.. Dallas area dont cha hate it when folks do you that way..they put an ad and you cant get a hold of them for love or money.. and in some cases you are dead serious and want to make a deal
good luck with your hunt, ever one needs a big bolt.. they have a good group here with them..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | roger that Madd, a long way from you.. Dallas area dont cha hate it when folks do you that way..they put an ad and you cant get a hold of them for love or money.. and in some cases you are dead serious and want to make a deal
good luck with your hunt, ever one needs a big bolt.. they have a good group here with them.. Yep, it's pretty frustrating, indeed....Tell ya what, Joker. I'll leave now, pick you up in Big D about 9pm with a few tacos, and we'll arrive at the dude's front door step I figure about 3:30am Sunday morning.....That'll show him!  | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Better be carefull, those Panhandle guys got bigger boom booms! Hey Joker, you can't beat a deal like that. Free Tacos and a road trip.
| | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | Better be carefull, those Panhandle guys got bigger boom booms! Hey Joker, you can't beat a deal like that. Free Tacos and a road trip. Yeah, Martin, we might just need some backup..... So, if you started driving right now...... (PS: I'll bring a coupla extra tacos for you too, bud...)
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | funny, I am sure the Doc would enjoy cruising with a 75 yr old man, you know all about big bolts Martin, you had a good one..
Maddog, not a big Taco guy but I could drink a lot of Dr. Pepper enroute..lol. The guy would probably not be there..
better stop the chit chat before the Mods get excited..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | Mine was a grain truck. See the before photo in the link below. Looks like a nice truck. I hope you can get it. As was mentioned--everyone needs a Big Bolt! | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | I agree with the two ton analysis from what is shown of the wheels, spring pack and diff. The sample photo of the blue one not only has a grain box but stock racks that could be lifted off when not carrying livestock. They were a very common sight on the farm and ranch land in the west. I hope you get it, this one looks like a fine survivor.
Even in Alberta I love the Dr. Pepper!
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: May 2016 Posts: 83 Shop Shark | | Shop Shark Joined: May 2016 Posts: 83 | You guys are THE BEST!!!!! | | |
