5 members (32Fordpuchoptop, treegrower, Jon G, Danielbolt, 1 invisible), 194 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#117998 10/13/2005 6:53 PM
7
Junior Member
Junior Member
7 Offline
My 71 C20 was painted about 3 yrs ago. Now I see cracks in the paint and in the sealant that is in the lip that runs around the cab roof. What is the correct way to restore this area? It seems that it was fine until I painted it.
#117999 10/13/2005 7:22 PM
Welcome! Probably will have to dig out the old, possibly wire wheel or spotbalst any rust, prime, use a seam sealer, I have found the stuff in a tube won't hold up,,3M two-part self leveling seam sealer is what the bodymen say to use. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#118000 10/13/2005 9:27 PM
71c20rock,
Just for your info, one of the men at my plant has a '72 p/u. He had it painted several years ago and this same area sealed. It is now rusted almost beyond repair. I mentioned your post to him and he said when he had his painted, the shop told his SOP on these gutters was removal. They told him they were always a problem area and eventually would be the source of cancer.
Stuart.
#118001 10/18/2005 7:32 AM
when i paint that area i take the sealer out clean it very good apply primer with brush paint the truck then take a brush and realy put a thick layer of paintin the gutter it lasts longer
#118002 10/20/2005 1:59 AM
Tab Offline
I drilled drain holes in my 62 roof gutters and applied "heavy duty drip sealer" . So far so good.
delete my account and pictures
#118003 10/20/2005 3:55 PM
Junior Member
Junior Member
SEM Products 39387 Dual Mix Self Leveling Seam Sealer is a great product to use once the old sealer is removed.
#118004 10/21/2005 10:31 PM
I think you've really got to be diligent about removing all the old seam sealer and absolutley get rid of as much corrosion as possible. It's all about the prepwork I think.
If you use the SEM two part self leveling or something similar, you've got to work fairly fast as it sets up and cures fast. Seemed to work pretty good, I just wish the working time was a little longer. Also, you need a special applicator. My paint store gave me one to use, just had to leave a deposit.
There's some recent threads on this topic. You might do a search.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
