| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1 Junior Member | | Junior Member Joined: Dec 2001 Posts: 1 | My 71 C20 was painted about 3 yrs ago. Now I see cracks in the paint and in the sealant that is in the lip that runs around the cab roof. What is the correct way to restore this area? It seems that it was fine until I painted it. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Welcome! Probably will have to dig out the old, possibly wire wheel or spotbalst any rust, prime, use a seam sealer, I have found the stuff in a tube won't hold up,,3M two-part self leveling seam sealer is what the bodymen say to use. Brian | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 71c20rock,
Just for your info, one of the men at my plant has a '72 p/u. He had it painted several years ago and this same area sealed. It is now rusted almost beyond repair. I mentioned your post to him and he said when he had his painted, the shop told his SOP on these gutters was removal. They told him they were always a problem area and eventually would be the source of cancer.
Stuart. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | when i paint that area i take the sealer out clean it very good apply primer with brush paint the truck then take a brush and realy put a thick layer of paintin the gutter it lasts longer | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I drilled drain holes in my 62 roof gutters and applied "heavy duty drip sealer" . So far so good.
delete my account and pictures
| | | | | Joined: Oct 2005 Posts: 4 Junior Member | | Junior Member Joined: Oct 2005 Posts: 4 | SEM Products 39387 Dual Mix Self Leveling Seam Sealer is a great product to use once the old sealer is removed. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I think you've really got to be diligent about removing all the old seam sealer and absolutley get rid of as much corrosion as possible. It's all about the prepwork I think. If you use the SEM two part self leveling or something similar, you've got to work fairly fast as it sets up and cures fast. Seemed to work pretty good, I just wish the working time was a little longer. Also, you need a special applicator. My paint store gave me one to use, just had to leave a deposit. There's some recent threads on this topic. You might do a search. -David | | |
