5 members (51sub, Stovebolt48, carbking, Wayne67vert, 1 invisible), 51 guests, and 1 robot.
Topics128,041
Posts1,055,593
#117970 10/12/2005 2:59 PM
I have a 52 1/2 t Chev deluxe 5 window. I have just about finished the frame off. I can't get those darn corner windows in to save my life. They sure came out easy enough. Any tricks?
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#117971 10/13/2005 3:54 AM
did you put the weatherstrip on the glass first? if not, that's what you should do..... and take a good piece of string and wrap around it and allow the ends to stick out... when you get the weatherstrip started in the window, you can pull on that string to help the weatherstrip go in place
#117972 10/13/2005 12:07 PM
Z
Z Offline
I struggled with mine also, but I put the rubber in the opening then fed in the glass with lots of soapy lubricant, I taped up the area around to keep from scratching and used several plastic putty knives. I actually had more trouble with the rear window than the corners, in fact I changed from Chevyduty rubber to Steele to get the rear window in, as the Steele was softer and less bulky. You can see here.
http://community.webshots.com/user/zeker6
Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#117973 10/13/2005 12:56 PM
Glenn, were these the original glass windows to your truck? Sometimes the repop glass is larger than the original and they are a bear to put in with new weatherstrip rubber.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#117974 10/17/2005 1:59 AM
Thx Guy',
Problem solved. I went out the next day and started on the opposite window. The weatherstrip looked like it had a larger channel. Sure enough, the side that was giving me grief had a smaller channel(rear window seal). With the proper larger channel seal the windows went right in. Those kind of things really tick you off. I spent hours trying to get that bad one in.
Glenn,
1952 Chevy 1/2-Ton
