| | | Forums66 Topics128,038 Posts1,055,583 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | I have a 52 1/2 t Chev deluxe 5 window. I have just about finished the frame off. I can't get those darn corner windows in to save my life. They sure came out easy enough. Any tricks?
Glenn, | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | did you put the weatherstrip on the glass first? if not, that's what you should do..... and take a good piece of string and wrap around it and allow the ends to stick out... when you get the weatherstrip started in the window, you can pull on that string to help the weatherstrip go in place | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I struggled with mine also, but I put the rubber in the opening then fed in the glass with lots of soapy lubricant, I taped up the area around to keep from scratching and used several plastic putty knives. I actually had more trouble with the rear window than the corners, in fact I changed from Chevyduty rubber to Steele to get the rear window in, as the Steele was softer and less bulky. You can see here. http://community.webshots.com/user/zeker6 Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Glenn, were these the original glass windows to your truck? Sometimes the repop glass is larger than the original and they are a bear to put in with new weatherstrip rubber. | | | | | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Thx Guy', Problem solved. I went out the next day and started on the opposite window. The weatherstrip looked like it had a larger channel. Sure enough, the side that was giving me grief had a smaller channel(rear window seal). With the proper larger channel seal the windows went right in. Those kind of things really tick you off. I spent hours trying to get that bad one in.
Glenn, | | |
