2 members (59 fleet, KEVINSKI), 157 guests, and 2 robots.
Topics128,034
Posts1,055,551
#1156396 03/23/2016 3:08 AM
Hey everyone. My grandfather-in-law is trying to restore a 1940 1.5 ton truck and we need piston rings. Chevs of the 40's is back ordered. Can any of you share a place I can check?
Also, I have a 1950 with a 216 and the 1940 is also a 216. I see sites like LMC have stuff for 47+ trucks. Would the 216 rings be the same? If they are it might open up my options.
1950 Chevrolet 3100 5 window
Original 216ci and SM420 4-speed
Root2812 #1156401 03/23/2016 3:28 AM
Crusing in the Passing Lane
One can order rings by dimension, most parts places only know modern VIN's. Look in a ring catalogue.
Ed
Root2812 #1156402 03/23/2016 3:30 AM
How about EGGE Machine. Probably a little pricey but.....
Root2812 #1156420 03/23/2016 4:42 AM
Per my 1959 Parts Book 37-53 216's all take the same ring sets.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Root2812 #1156421 03/23/2016 4:51 AM
eBay has a number of them listed.
My Blog
Root2812 #1156424 03/23/2016 4:59 AM
Any good old school NAPA store that still has the books on the counter will have them for you in a day.
Root2812 #1156574 03/24/2016 1:47 AM
Thanks Guys. It helps knowing the rings are the same up though 1953. I'll call the local part stores and see what I can find. Knowing they are the same up though 53 opens up a lot of venders online if I have to go that route. I'll try ebay if I have to but I am always skeptical of getting parts on there because they might be cheap and its harder to return them than at a normal store or reputable online store.
Root2812 #1156579 03/24/2016 2:04 AM
Update, thanks to all of your help I found the rings. Sealed Power makes them. Part number e-103x. I have used Sealed Power on newer stuff and know they are good. I should be able to order them at the store now. Even if the people there have no records for tucks this old they should be able to look up by part number. Worst case would be I order them and I see Summit Racing has them in stock.
Root2812 #1178843 08/19/2016 7:14 AM
How did your ring job work out? I'm in the same spot with my '49 216. My Pistons are aluminum and have 3 grooves. Top groove has one big ring. 2nd groove has 2 rings and a spacer under the rings. 3rd groove has two waffle rings in the middle one on top of the other with a top and bottom ring. I don't know if they're original or not but these are the Pistons I have. # 3835996 GM1 with a notch on top.
Rais'em from the dead.
Lazarus #1178929 08/20/2016 2:57 AM
Lazarus, check the bore on your 216 as it maybe a 235 with that part number piston. Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Root2812 #1178950 08/20/2016 6:22 AM
The bore is 3.5.
Root2812 #1179007 08/20/2016 9:22 PM
