7 members (Goach2, Dave1234, IHPWR, Hotrod Lincoln, TUTS 59, Peggy M, 1 invisible),
73
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | 1948 Chevrolet Pick-up (1/2 Ton) actually my chassis is off a 1951 truck; noticed I have a small leak on my rear differential, seems like it is coming from the Front, where the Driveshaft connects. Was just curious, is there a Gasket for this, or supposed to use sealant? If sealant, what type/brand of sealant is best, how large of a bead to run, what do folks on the forum recommend? Also, when I put everything back, what Ft Lbs of torque should I tighten the nuts to? Appreciate any insights! | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | If you have a rear end Like This. And it is leaking at the upper 5.504 Carrier arrow. Where the torque tube enters the cast carrier housing. Leak at Left arrow, Torque tube to carrier housing connection. Picture To rectify the leak some people have run a weld at the connection. But I'm sure there is some kind if oil resistant sealant that would work also. | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Thanks, that looks like my driveline. it is leaking, best I can tell at the bottom of where it connects to the axle, at the 6 o'clock area. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I prefer the gray high torque by permatex. A good fat bead should do and then after it cures you can trim it around the rear end.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Thanks, that looks like my driveline. it is leaking, best I can tell at the bottom of where it connects to the axle, at the 6 o'clock area. If it is leaking where the cast carrier housing connects to the axle housing. It might be a simple tightening of the carrier nuts. See Lubrication Leaks, (b.) Manual does not show torque spec on carrier nuts. it just says tighten securely. Read Number 2 Under Rear Axle Assembly | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Isn't that reference about a two speed rearend? I think the leak here is where the torque Tube is pressed into the housing. I wonder if something is cracked. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Isn't that reference about a two speed rearend? All tonnage Advance Design Series trucks used a banjo type axle housing. Requiring a front carrier gasket and rear cover gasket. Page 1 and Page 2 There is one troubleshooting section for all four types of Axles. See: 4-40 under REAR AXLE AND SUSPENSION there is 3 troubleshooting pages. Lubrication Leaks, I assume are referring to all four carriers. Interestingly they don't mention rear cover leaks. I think the leak here is where the torque Tube is pressed into the housing. They where probably pressed and definitely riveted and maybe some type of sealant was applied. See Rivets above Arrows 1 and 16 Could be leaking at that joint. I wonder if something is cracked. That is a possibility. | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | It is leaking where the shaft head is bolted (10 bolts) to the rear axle, a very slow drip, at the front of the axle. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Did you try to tighten the 10 carrier nuts? | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Yep, it turned out 3-4 of them on the bottom were loose, about 3/4 of 1 full turn on each nut. I haven't seen any more leaking yet, will keep an eye on it. My sincere thanks! | | |
