3 members (Shaffer's1950, UtahYork, Rich'sToys), 99 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
#1178012 08/13/2016 8:50 PM
Hi guys,
These motor mounts are in my 1952 3100. I will be installing a 350 SB and auto trans. The motor mounts on the engine are the u shaped ones that take a large bolt through the mount and the frame mount. My question is this: What motor mounts do I need on the engine to use these stands on the frame? Or do I need to change the frame mounts to use the 350 SB?
motor mounts
mounts
Ralph
3B Offline
Hy Mickey3100, your question is very confusing to me, your pictures are of a much more modern crossmember and frame engine mounts for a V8 or any of the post 1962 inline sixes except the 292. Are these parts already installed on a 1952 3100 Chassis?
Yes, the cross member is from a later model Chevy truck, 1972 i think. Already installed on my 1952 frame.
Ralph
If I understand the question I'd look at a motor mount for a 72 Chevy pickup and see if it will bolt to what you have and to the 350 engine.
Anchor motor mount #2337 has center bolt but don't know if it'll work.
