| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 22 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 22 | Hi guys, These motor mounts are in my 1952 3100. I will be installing a 350 SB and auto trans. The motor mounts on the engine are the u shaped ones that take a large bolt through the mount and the frame mount. My question is this: What motor mounts do I need on the engine to use these stands on the frame? Or do I need to change the frame mounts to use the 350 SB? motor mounts mounts
Ralph
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mickey3100, your question is very confusing to me, your pictures are of a much more modern crossmember and frame engine mounts for a V8 or any of the post 1962 inline sixes except the 292. Are these parts already installed on a 1952 3100 Chassis? | | | | | Joined: Jul 2016 Posts: 22 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 22 | Yes, the cross member is from a later model Chevy truck, 1972 i think. Already installed on my 1952 frame.
Ralph
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If I understand the question I'd look at a motor mount for a 72 Chevy pickup and see if it will bolt to what you have and to the 350 engine.
Anchor motor mount #2337 has center bolt but don't know if it'll work.
